Including firm fixed-effect makes the coefficient insignificant
Posted: Wed Sep 14, 2016 11:08 am
I am running panel regression with period and firm fixed effect. I have modeled several panel regressions for my research considering what other researchers did in the past for analyzing similar data. I also used new model specifications for a robustness check. Including period and firm fixed effect in the main regression are somehow OK, since the coefficient on the variable of interest is still significant. However, when I include firm fixed effect the t-stat drops from 4.13 to almost 1.80.
For the robustness check, I used three other model specifications. The coefficient on the variable of interest is highly statistically significant (t-value is almost 7) when I only include period fixed-effect. However, when firm fixed effect is included, the coefficient is no longer significant. Generally speaking, what causes such a huge difference by including firm fixed-effect? In this case when there is a huge difference, is it OK to exclude firm fixed effect? Do you think that the reason might be due to the fact that a large fraction of the dependent variable is explained by firm fixed-effect, and that is why the coefficients on the independent variable is no longer significant.
I really appreciate it, if you could help. Thanks in advance!
BR
Sara
BR
Sara
