Merging 2 workpages
Posted: Thu Sep 01, 2016 5:21 pm
by Andre2016
I have a workfile with 2 pages and I'd like to merge them into one. Some series in the 2nd page don't exist in the 1st one and I'd like them to be integrated using 3 criteria (here: model, category and country).
I try to use the following command but it does not work:
copy(m) 2000PRSTEVFLEETBYAGE\* 19601999FLEETBYAGE\
Thank you for your help.
Re: Merging 2 workpages
Posted: Thu Sep 01, 2016 7:04 pm
We'll need more information on exactly what you mean
Posted: Thu Sep 01, 2016 8:29 pm
by Andre2016
Hi Gareth,
So I have 2 pages in the same workfile :
page1 called "FLEETBYAGE19601999"
Page2 called "FLEETBYAGE20002016"
both pages have the same format and I'd like to merge the two in one page without deleting any data
Posted: Thu Sep 01, 2016 10:37 pm
Copy them from the source page, Paste Special on the destination page, and use General Match Merge. Then enter the ID series you want to use.
Posted: Fri Sep 02, 2016 2:48 pm
by Andre2016
Thanks Gareth.
The issue is when I try to do that, since my old and new data have the same name (for example in the attached workfile, I have "year" in both pages) the first one is erased.
is there a command so that when I paste year from page 1 to page 2 the two are merged ?
So far I used the following command unsuccessfully :
copy(m) FLEETBYAGE20002016\year FLEETBYAGE19601999\
Posted: Fri Sep 02, 2016 5:27 pm
When you do the copy/paste it will ask you if you want to merge the objects.
Posted: Fri Sep 02, 2016 10:41 pm
by Andre2016
I solved the issue using pageappend.
