Significance of impulse response VAR
Posted: Fri Aug 05, 2016 3:02 pm
by sofp
i'm estimating an unrestricted VAR and right now I went thought the impulse response function. I don't understand how to read the significance of the IRF. For example I don't understand on which basis from the IRF graph I can say that real GDP response to oil price shock is whether significant or insignificant.
Thanks.
Re: Significance of impulse response VAR
Posted: Fri Aug 05, 2016 6:28 pm
by dakila
If the confidence interval (or band) does not contain zero (horizontal axis) then it is statistically significant.
Posted: Sun Aug 07, 2016 2:14 am
by sofp
Thank you for your answer. I'm still a little bit confused about it. So can I ask you to give me an example based one these impulse responses? Thanks
Posted: Sun Aug 07, 2016 2:24 am
by dakila
dlogrgdp to dlogop: impulse responses are insignificant for all periods
dlogop to dlogop: impulse responses are significant for 1st period (impact period)
dlogstir to dlogop: impulse responses are significant for 2nd period
dlogltir to dlogop: impulse responses are significant for 1st period (impact period)
Posted: Sun Aug 07, 2016 2:43 am
by sofp
Thank you so much!
Posted: Fri May 18, 2018 8:34 am
by soetirl13
just wondering. What does it mean when it's insignificant? is it meaningless then??
Posted: Fri May 18, 2018 9:11 am
by startz
All it means is that there is not strong statistical evidence that the response is different from zero.
Posted: Sat Jul 16, 2022 7:07 pm
by ericsugandi
@dakila: Is there any textbook or other material that I can refer to on how to interpret IRF confidence intervals as you did? Thanks very much for your help.
Posted: Fri Sep 23, 2022 12:10 am
by virenrehal
As requested, this link contains information on the estimation and interpretation of IRFs (Impulse Responses) for both VAR and VECM: https://spureconomics.com/impulse-respo ... -and-vecm/
The interpretation is quite straightforward, although it does depend on how the IRFs are computed. Generally, they are computed using shocks in terms of Standard Deviation or in terms of absolute values of the variables.
Posted: Fri Jan 06, 2023 10:42 am
by aawoad
Hello everyone
I have a question on the same matter
What is the link between causality, PVAR findings, and impulse response (IRF) in PVAR? If the causality shows a significant bidirectional relationship between X and Y variables, do the IRF should reflect the same? Also, if the PVAR results show X has a significant impact on Y, do the IRF should reflect the same?
Feedback is highly appreciated
