Holt-Winters forecasting
labenroth
Postby labenroth » Wed Nov 11, 2009 4:58 pm
Question from a newbie:
How do I get the Holt-WInters smoothing option to forecast m-periods beyond the end of my data range?
Thanks in advance...
trubador
Did you use forum search?
Re: Holt-Winters forecasting
Postby trubador » Thu Nov 12, 2009 2:52 am
Open your series and select Proc/Exponential Smoothing. A self-explanatory dialog box will be opened. You do not have to specify a forecast horizon in addition to estimation sample, since EViews will calculate forecasts starting from the first observation after the end of the estimation sample.
labenroth
Postby labenroth » Thu Nov 12, 2009 10:34 am
trubador-
THanks for responding. I don't seem to be doing it right then:
1) I open a series called spa containing 43 quarterly observations, 1999Q1 to 2009Q3.
2) I open Proc>Exponential Smoothing>
3) From the dialogue box I select: Smoothing Method=Holt-WInters Multiplicative; Smoothing Parameters=E,E,E; Smoothed Series="spasm"; Estimation Sample=1999Q1 2009Q3; Cycle for Seasonal=4
4) I open the resulting series "spasm" and find that there are 43 quarterly observations, 1999Q1 to 2009Q3. There are no forecast values for the next 4 quarters (2009Q4, 2010Q1, 2010Q2, 2010Q3) beyond the end of the estimation sample.
Why doesn't resulting series "spasm" should contain forecast values for the four quarters 2009Q4, 2010Q1, 2010Q2, 2010Q3 beyond the end of the estimation sample?
Postby EViews Gareth » Thu Nov 12, 2009 10:52 am
Does your workfile contain observations for those dates?
If you don't have those dates in your workfile range, then they will not be forecasted.
labenroth
Postby labenroth » Thu Nov 12, 2009 1:13 pm
Forgive me if I misunderstand:
I have actual (observed)quarterly data for the interval 1999Q1 to 2009Q3. I know the data exhibits seasonality just by inspection. My goal is to: 1) quantify the seasonality, and 2) forecast the data for the next 4 quarters into the future 2009Q4, 2010Q1, 2010Q2, 2010Q3.
I obviously have no actuals for these future periods. From my reading of H-W methods, I should be able to project this forecast for m-periods ahead, beyond the range for which I have observed data (actuals).
Postby startz » Thu Nov 12, 2009 1:16 pm
Make sure the workfile range goes through 2010Q3, even though your data doesn't.
labenroth
Postby labenroth » Thu Nov 12, 2009 1:21 pm
Ahhh....(sound of forehead smack)
Thank you all for the help!
