Estimating the conditional CAPM
CHRIS83
Postby CHRIS83 » Wed Nov 11, 2009 3:01 am
I would like to modify the EViews sample program tv_garch.prg according to the conditional CAPM.
Does anybody know how to adjust the estimating procedure in that program?
In particular the mean equation deviates from a normal multivariate GARCH-M process as it includes conditional covariances.
The specification of the CAPM mean equation is shown in the attachment. The variance equation follows a simple BEKK-process.
Thank you in advance
CHRIS83
mean equation.doc
conditional CAPM mean equation
(16.5 KiB) Downloaded 454 times
trubador
Did you use forum search?
Re: Estimating the conditional CAPM
Postby trubador » Thu Nov 12, 2009 2:58 am
You can find several examples if you search the forum. For instance:
Example-1
Example-2
CHRIS83
Postby CHRIS83 » Mon Nov 16, 2009 7:23 am
Hello trubador,
thank you for your help.
However, I still have the problem that the GARCH-term in the mean equation has to be multiplied by an exogenous vector (the vector of portfolio weights). Is there any possibility to adjust the program to that conditional CAPM specification?
Many thanks,
CHRIS83
trubador
Postby trubador » Tue Nov 17, 2009 6:22 pm
Unfortunately, you cannot use matrix multiplication in LogL object. You can either write the resulting terms one by one or try to specify them in terms of series multiplication...
