Using Eview's 9.5 - having trouble saving output from fcstavg commands to a predefined spool named spool1
here's the code:
v1606354.sheet
v1606354.fcastavg(wgttype=aic) eq1 eq2 eq3 eq4 eq5
spool1.append vi606354.sheet
tried to freeze the output and save but to no avail - suggestions - thanks
code to save fcstavg tables to a spool
Re: code to save fcstavg tables to a spool
If you want to append to an existing non-empty spool called spool1:
or
output(s) spool1
pon
poff
freeze(spool2) v1606354.fcastavg(wgttype=aic) eq1 eq2 eq3 eq4 eq5
spool1.append spool2
