Hello everybody,
I am doing the ADF unit root test and I want to store the value of the coefficient associated with the @TREND, but knowing that in the ADF test the position of the said coefficient varies with every series, I wonder if there is a fuction which gives me the position of the string "@TREND" in a table ?
Thank you in advance
find the position of a string in a table
Re: find the position of a string in a table
There isn't one, unfortunately, so you'd have to loop through the elements of the table one at a time yourself.
Although given your specific application, I would have thought it would be easier to estimate the ADF equation yourself in an equation object rather than use the built in adf test.
Thank you anyway !
