Bootstrap VAR [Simple/Bayesian VAR]
Posted: Wed Jun 01, 2016 4:28 am
Dear all,
I'm bootstrapping a simple VAR (with 4 variables; that was converted to a model "MODEL_F") - in order to generate a few thousand forecast over a sample (see code below):
MODEL_F.stochastic(i=b, d=f, v=t, s={%simulation_period}, r={%no_simulations}, c=f, p=BS)
MODEL_F.solveopt(s=s, o=b, struct=t, w=t, v=t)
MODEL_F.solve
My question is how the bootstrapping procedure works exactly, in the sense that the forecast probably converges to the mean over the long run - but there are resampled shocks added on top of the forecasted values (over the forecast)? In each forecast, the sample is reshuffled and the VAR re-estimated (before generating the forecast)?
I've searched for the answer in the Eviews (8.1) help, the manual(s) provided (pdf(s)) and in the Jean Louis Brillet's manual/guide (http://www.eviews.com/StructModel/structmodel.html).
However, I could not find an answer.
Could you help?
MODEL_F.solve
Could you help?
