Test of Equality for Paired Samples
Posted: Mon May 23, 2016 8:22 am
What is the formula used for equality of means testing for a group of two series?
I can replicate the results for the Welch t-test. I'm interested in why, when running the tests and specifying "common sample" the results are identical as not selecting "common sample". I have calculated the test statistic for paired sample by hand which I verified with excel's & R's calculation. The same for the common t-test. However, EViews gives the same t-stat for common sample or not. Is there a way in EViews to use the t-stat for paired samples to test difference-in-means?
Using EViews 9.5
Using EViews 9.5
