logical count
londonphd
logical count
Postby londonphd » Mon May 16, 2016 5:55 am
I want to count the number of observations that are greater than say a 100x4 matrix. The code will be used in a loop where the rows/columns of the matrix will be indexed i.e.loop goes over each element of the matrix. In each run of the loop, I want to count elements greater than 1 per row.
I tried the following code, it did not help.
mat1(!i,1) = @sum(matname(!i,!j)>1)
Re: logical count
Postby EViews Gareth » Mon May 16, 2016 10:03 am
I don't follow
londonphd
Re: logical count
Postby londonphd » Mon May 16, 2016 11:27 am
I don't follow
Hello Gareth,
I have data that is stored in a 100x5 matrix. I want to count how many elements per row are greater than 1.
THanks.
Re: logical count
Postby EViews Gareth » Mon May 16, 2016 11:43 am
Brute force:
vector(100) count for !i=1 to 100 !count = 0 for !j=1 to 5 if x(!i,!j)>1 then !count=!count+1 endif next count(!i) = !count next
londonphd
Re: logical count
Postby londonphd » Mon May 16, 2016 11:51 am
Brute force:
Wow, thanks. But this probably makes my already inefficient code a more inefficient one :)
Re: logical count
Postby EViews Gareth » Mon May 16, 2016 12:02 pm
If it is a one-off operation, then it probably takes 100th second, and the most efficient could be done in 1000th second. No big deal.
If you're doing it 1000 times, or as part of an optimization procedure, then yeah, you might want to think of something more efficient.
londonphd
Re: logical count
Postby londonphd » Mon May 16, 2016 12:18 pm
I cannot think of anything else. Will use it and have to just wait a few seconds I guess. Big Thank you!
Re: logical count
Postby EViews Glenn » Mon May 16, 2016 1:27 pm
matrix(10000, 5) a nrnd(a) matrix(10000, 5) b b = 1 vector count count(1) = @sum(@egt(a, 1))
Not certain, but this should be faster.
Re: logical count
Postby EViews Gareth » Mon May 16, 2016 1:38 pm
Couldn't remember if @egt was in EV10 only :D
