Model Printview Suggestion
xprimexinverse
Contact:
Postby xprimexinverse » Sun May 15, 2016 3:51 pm
Let me begin by saying that the printview option of model objects introduced in EViews 9.5 is an excellent new feature!
The suggestion here comes out of my observation that scalar objects are not replaced by their numerical value when using the printview option.
On the back of that observation, would it be possible to introduce replacement for scalar objects in the printview? Also, how about for vector objects? They seem to get replaced depending on how the equation they appear in are appended to the model.
The sample code below demonstrates. Bear in mind that I may not have covered all of the possible combinations. Could this be investigated?
Two final points.
1) I'd like to bring to the attention that "mod.printview" does not seem to work when using the command line.
2) What is your advice on the best practice for creating (programming) a model that contains both estimated and calibrated coefficients?
Thanks!
Graeme
Sample Code
' Create workfile wfcreate a 2000 2010 ' Define scalar, coef, and vector objects scalar COEF1 = 1.0 coef(2) COEF2 vector(2) COEF3 COEF3.fill 0.0, 1.0 ' Create some toy data series W = nrnd + @trend series Y = nrnd + @trend series X = nrnd + @trend series Z = nrnd + @trend ' Create equations using different combinations of objects equation EQ01.ls Y = c(1) + COEF1 * X equation EQ02.ls Z = COEF2(1) + COEF2(2) * X equation EQ03.ls W = COEF3(1) + COEF3(2) * X + c(1) ' Set up a model model mod mod.append :EQ01 ' COEF1 not replaced mod.append :EQ02 ' COEF2 is replaced mod.append :EQ03 ' COEF3 is replaced mod.append X = COEF3(1) + COEF3(2) * X(-1) ' COEF3 is not replaced ' Inspect the printview mod.printview(idents, signif=3) ' Does not work
Re: Model Printview Suggestion
Postby EViews Gareth » Tue May 17, 2016 3:33 am
The next patch will fix the command line not working.
There will also be a change that means that if you click Break Links and select a number format other than "Default", the printview will display scalar objects to that format. It doesn't yet handle matrices/vectors/coefs. Might have to wait for EV10 for that.
xprimexinverse
Contact:
Postby xprimexinverse » Tue May 17, 2016 12:22 pm
Excellent! Thanks, Gareth.
Elderfield.A
Postby Elderfield.A » Mon Sep 11, 2023 10:15 pm
Did this ever get actioned?
Postby EViews Gareth » Tue Sep 12, 2023 8:42 am
I believe it did not.
