Estimation ARDL model in Eviews9
Posted: Sun May 15, 2016 6:42 am
Hello…I am new to ARDL model and Eviews9.
I am estimating the equation: export = c + GDP + Real exchange rate + Exchange rate volatility
I am using the ARDL model and Eviews9.
May I have two questions?
(Q-1). why is the value of SR coefficient from Bounds Test and from the Long Run estimation different? Should they be the same values?
Based on the attached files: SR coefficient of D(LEXPO(-1)) = -0.136228 (from Bounds Test), but it is -0.113048 (from Cointegration and long run).
(Q-2) Based on question-1 above, which coefficient is considered as SR coefficient? -0.136228 (from Bounds Test)? Or -0.113048 (from Cointegration and long run)?
Thank you very much.
