Compare two times
kszynkar
Compare two times
Postby kszynkar » Thu May 05, 2016 7:09 am
I was wondering how to compare two times. I would like to do something similar to:
if @dateval("17:00")<@now then
Re: Compare two times
Postby EViews Gareth » Thu May 05, 2016 8:00 am
The syntax you're using will work just fine. The problem is, what is "17:00"? That isn't a date/time. Do you want to tell whether the time right now is less than 17:00 today? If so, I think the easiest way is just:
if @datepart(@now, "hh")<17) then
Note that only works because you're testing for an exact hour. If you wanted 17.30, it would be more tricky.
kszynkar
Postby kszynkar » Thu May 05, 2016 11:20 pm
I needed to test it to the minute at least, but can use this way. Thanks
