Forecast errors for geometric random walk
Posted: Tue May 03, 2016 2:51 am
Hi!
I am trying to generate confidence intervals for a k step prediction of a geometric random walk with drift.
First, I estimate the drift parameter by running a least squares regression on DLOG(X) on data from 1950-2011 as per below, whereby the constant (C) in the regression is the point estimate for the drift parameter. I then make forecasts of X (i.e. original series, not dlog) for 2012 to 2070 using EViews built in forecast feature, and also enable the option to output forecast errors. This gives me a series of forecast errors as a new variable.
1. What's the interpretation of these forecast errors? Specifically, are they the forecast error of k step ahead forecasts of the level of the original series X, for each year 2012-2070?
2. How are the forecast errors calculated?
3. What I would really like to do in the end is to achieve a x% prediction confidence interval for the level of X. Is there any way to achieve this using EViews' built in features, or do I have to calculate those myself using the standard errors of the regression?
Many thanks!
Per
Dependent Variable: DLOG(X)
Method: Least Squares
Date: 05/03/16 Time: 09:14
Sample (adjusted): 1951 2011
Included observations: 61 after adjustments
C 0.007820 0.003431 2.279500 0.0262
R-squared 0.000000 Mean dependent var 0.007820
Adjusted R-squared 0.000000 S.D. dependent var 0.026793
S.E. of regression 0.026793 Akaike info criterion -4.385079
Sum squared resid 0.043073 Schwarz criterion -4.350474
Log likelihood 134.7449 Hannan-Quinn criter. -4.371517
Durbin-Watson stat 1.445670
Many thanks!
Per
