Instability of threshold regression
Posted: Wed Apr 13, 2016 7:23 am
I'm using Eviews 9.0, and have been experimenting with the threshold model. I see in a pure AR model where only dependent variable and its lags are included, the lag length affects which variable is chosen as the threshold variable. This is understandable since models with different number of lags are basically different models. However, when I use the same model (same lag length), the pool of possible threshold variables affects which variable is chosen as the threshold variable. For example, although variable X1 and X2 are never chosen as the threshold variable, if I include X1 and X2 as possible threshold, then X3 is chosen as the threshold, whereas if X1 and X2 are not included as possible thresholds, X4 is chosen as the threshold. The only reason I can think of is that X1 and X2 have shorter time series, so it might affect the number of observations when they are included. However, when they are included and X3 is chosen, eviews shows that it is using the full time series, not the short time series restricted by X1 and X2. So it doesn't seem to explain the problem.
Since the threshold chosen by Eviews changes when the pool of possible threshold variables changes, I become skeptical of the results in general. Could you help explain why this happens, and what factors affects the selection of threshold variable? Many thanks!
