Updating data in imported series
Mukanov
Postby Mukanov » Fri Apr 01, 2016 6:53 am
Hello everyone :)
I have an issue with managing data "up-to-date".
For example to add actual and forecasted values for BRENT price:
dbopen(type=fredv1, server=api.stlouisfed.org/fred) fetch("link", m) mcoilbrenteu
Is there some easier way to do, except of this:
smpl 2016M03 2016M03 series mcoilbrenteu=40 smpl 2016M04 2016M04 series mcoilbrenteu=40 smpl @all
Through something like this (I know that it is not working):
mcoilbrenteu.insertobs(2016M03) 2 series mcoilbrenteu(2016M03)=40 series mcoilbrenteu(2016M04)=40
Thank you in advance!
P.S. Eviews version 9.5
Re: Updating data in imported series
Postby EViews Gareth » Fri Apr 01, 2016 7:59 am
It isn't exactly clear what you're asking, but perhaps series.adjust will help you.
http://www.eviews.com/help/helpintro.ht ... 23ww200856
Mukanov
Postby Mukanov » Fri Apr 01, 2016 8:10 am
I want to change exact date value in series by code lines, without changing sample every time :series:
To be clear BRENT price that I imported from FRED was looking like this:
2015M12 38.01
2016M01 30.7
2016M02 32.18
2016M03 NA
2016M04 NA
And I want to fill with new data and forecast, to make it look like this:
2015M12 38.01
2016M01 30.7
2016M02 32.18
2016M03 40
2016M04 40
Is there is other way to do it, except of changing sample? Because it is not convenient :|
Postby EViews Gareth » Fri Apr 01, 2016 9:13 am
No, but you only need to change the sample once.
Mukanov
Postby Mukanov » Fri Apr 01, 2016 10:46 am
Yeah, If numbers will be the same (equal to 40) it will work, but if not, sample must be changed each time, am I right :?:
For example to get series like this:
2015M12 38.01
2016M01 30.7
2016M02 32.18
2016M03 40
2016M04 45
2016M05 44
2016M06 42
2016M07 50
2016M08 48
Postby EViews Gareth » Fri Apr 01, 2016 10:51 am
If you're using .adjust you only need to set the sample to the first period that needs to be changed.
Mukanov
Postby Mukanov » Fri Apr 01, 2016 11:48 am
So it should look something like that (don't have an opportunity to check it right now):
smpl 2016M03 2016M08 mcoilbrenteu.adjust = 40 45 44 42 50 48
Thank you very much, now I understand! :wink:
