Pool estimation
Posted: Sat Nov 08, 2008 6:22 am
by jabro
can somebody please help
My sample is as follows:
36 countries
1999 - 2007
whenever im trying to estimate my equation, eviews respond by saying insufficient observations, what might be the problem?
Re: Pool estimation
Posted: Sat Nov 08, 2008 9:48 am
36 countries
1999 - 2007
First check to be sure that your data isn't full of NAs.
Second, you might post your equation here so people can see what you're trying to estimate.
Re: Pool estimation
Posted: Sat Nov 08, 2008 1:10 pm
by jabro
i got right, thanks
what is the meaning of the following when you are estimating "near singular matrix"
Re: Pool estimation
Posted: Sat Nov 08, 2008 1:38 pm
i got right, thanks
It means there is near linear dependence among your independent variables, near perfect multicollinearity. In practice, it usually means you have accidentally specified a redundant variable.
Re: Pool estimation
Posted: Sat Nov 08, 2008 2:11 pm
by jabro
thanks startz
what is causing the near singular matrix is my dummy variable. will you please be so kind and help me as to how i should generate my equation and dummy variable
what i am trying to estimate is the relationship between telecommunication perforemance (dependant variabl) and investment in the sector, competition in the sector with the value of 1 if the sector is open for competition (a value of 0 if the sector is not open for competition), and the regulation in the sector (value of 1 if the regulator is autonomous and value of 0 if the regulator is not autonomous). meaning that competition and regulator is represented by a dummy variable.
as i said my sample is 46 countries, period 1996 to 2006
Yit = q1 + q2Dit + q3Dit + B2X2it + uit
fixed telephone line per 100 subcribers = intercept + dummy variable for competition (varies in time and individual) + dummy variable for regulation (varies in time and individual) + Fixed investment in the sector
what is the best in this case fixed or random effect
Re: Pool estimation
Posted: Sat Nov 08, 2008 2:26 pm
thanks startz
Is it true that one of the dummy variables is always 1 when the other is 0? If so, you are in the "dummy variable trap," which would explain your problem.
Re: Pool estimation
Posted: Sat Nov 08, 2008 2:31 pm
by jabro
i am confused. to put it in perspective lets say i have three countries 2 of them are open for competition and the other not. does the latter not imply that the dummy variable for the two will be one and the other zero.
Re: Pool estimation
Posted: Sat Nov 08, 2008 2:55 pm
Just look at your data. If for
every observation either D1=1 and D2=0
or D1=0 and D2=1, then you have fallen into the dummy variable trap.
Re: Pool estimation
Posted: Sun Nov 09, 2008 5:30 am
by jabro
how do i insert time variant and non time variant variable in eviews
Re: Pool estimation
Posted: Tue Nov 18, 2008 11:17 am
by jabro
can someby please help me to interpret the following:
Dependent Variable: GDP?
C 5.92921 0.470135 12.61173 0
TIT? 0.009881 0.018972 0.520837 0.6035
TTS? 0.141849 0.022275 6.368211 0
Weighted Statistics
R-squared 0.671108 Mean dependent var 0.609641
Adjusted R-squared 0.665534 S.D. dependent var 0.222395
S.E. of regression 0.128618 S um squared resid 1.952029
F-statistic 120.3902 Durbin-Watson stat 0.77652
Prob(F-statistic) 0
Re: Pool estimation
Posted: Mon Jul 06, 2009 7:23 am
by probettly
Hi all,
I am also having a problem with near perfect multicolliniearity in my panel data regression.
To make a story short, I am estimating influace of labour migration on unemployment rates in local regions.
When I run both entity and time fixed effects regression model, I get message with: "near singular matrix".
It is obvious for me that minimal wage that is constant between regions but varies between time periods causes near perfect multicollinearity.
My question is: how can I avoid the problem, and run both entity and time fixed effects regression model with my minimal wage variable?
Is it possible at all?
Thanks in advance!
Re: Pool estimation
Posted: Mon Jul 06, 2009 9:43 am
You can't have fixed effects and a variable which is constant within a group. It doesn't make any sense, which is what EViews is telling you. You probably want to drop the minimum wage variable.
Re: Pool estimation
Posted: Mon Jul 06, 2009 10:04 am
by probettly
Thx for fast reply,
I understand that fixed effect regression will not work with minimal wage variable.
I wonder if it's possible to make time fixed effect for all variables except minimal wage and entity effect for all variables at the same time.
And if not (what I assume) than what would you suggest:
1) dropp minimal wage > get less significant variables but both entity and time fixed effects regression
or
2) keep minimal wage > get more significant variables but only cross-section fixed effects?
(in both cases R squered adjusted is preety much the same around 0.80)
Best,
Anna
Re: Pool estimation
Posted: Thu Jul 29, 2010 10:02 am
by morad
hi,
i have also same problem. I am working with pool data, it consists of 8 cross-sections(8 companies) over 738 days using SUR.
i see the following error"near singular matrix" when i use an only dummy variable of my model ( d1=1 in only 6 days and d1=0 for other days) as cross section spesific coefficients.
it is important for me to have their spesific coefficients through fixed effects.
i would be grateful if somebody helps me know how to solve it.
thanks
