i can't get my programs to run in quiet mode..
Posted: Fri Mar 25, 2016 6:14 pm
by russellrobins
i can't get my programs to run in quiet mode---i tried version 8 and version 9
i am running a loop with 10,000 iterations requiring regressions and tables...etc----i don't want all the updates flashing on the screen
it takes forever
what am I doing wrong
thanks
Russ
Re: i can't get my programs to run in quiet mode..
Posted: Fri Mar 25, 2016 6:22 pm
Hard to know what you're doing wrong without knowing what you're doing.
Perhaps you could post the workfile/program and describe how you're making it run quiet.
Posted: Sat Mar 26, 2016 2:56 am
by russellrobins
here is the program......i run the program from the Dialog box
thanks for the help
smpl @first @last
mode quiet
vector (10000) chow_values
rndseed 1
scalar i
FOR i = 1 TO 100
delete eq2 mytab
'series y_stable = 2 + 1.2*market + .8*hml -.5*smb + 2*nrnd
series y_stable2 = 2 + 1.2*market + .8*hml -.5*smb + 2*nrnd
'equation eq1.ls y_stable c market hml smb
equation eq2.ls y_stable2 c market hml smb
eq2.chow 100
freeze(mytab) eq2.chow 100
chow_values(i) = mytab(6,2)
Posted: Sat Mar 26, 2016 8:37 am
Posted: Sat Mar 26, 2016 1:53 pm
by russellrobins
perfect, that worked
thanks
but why would anything show up, if I am running in quiet mode? Just curious
Posted: Sat Mar 26, 2016 2:09 pm
The command:
has an implicit
show in front of it. Show overrides quiet.
Posted: Sat Mar 26, 2016 2:25 pm
by russellrobins
very cool
thanks
Posted: Sat Mar 26, 2016 2:26 pm
by russellrobins
is there anyway of knowing what has the implicit show?
Posted: Sat Mar 26, 2016 2:47 pm
Not really. Generally anything that only displays results (like the Chow test) will have a show. There is absolutely no reason to perform the Chow test without a freeze statement unless you wanted to see the results, so if you do perform a Chow test without a freeze, EViews will show the results.
