Robust Regression
Posted: Fri Oct 02, 2009 3:21 pm
by trubador
Attached is a subroutine to carry out a robust regression analysis in EViews. The usual disclaimer applies.
'Robust Regression 'Reference: Adapted from the MATLAB code written by James P. LeSage, Dept of Economics, University of Toledo. Original version of the code is available at: http://www.spatial-econometrics.com/regress/robust.m call robustreg(y,x,4,1) ' ---------------------------------------------------------------------------------------------------- ' Program arguments '----------------------------------------------------------------------------------------------------- 'series y ' dependent variable 'group x ' group of independent variable(s) (including single series) 'scalar model ' 1 = Huber's t function, 2 = Ramsay's E function, ' 3 = Andrew's wave function, 4 = Tukey's biweight 'scalar addc '1 = adds a constant ' ---------------------------------------------------------------------------------------------------- subroutine robustreg(series y,group x,scalar model,scalar addc) 'The following objects will be created through the program. 'If necessary, assign different names to avoid overwriting. %coef = "beta" %eq1 = "ols" %eq2 = "itrw" %table = "output" %ser = "weight" %resid = "resw" %const = "constant" 'Get the names of dependent and independent variables %dep = y.@name %indep = x.@name 'Generate a series for the constant if addc = 1 then series {%const} = 1 {%indep}.add {%const} endif 'Determine the number of independent variables. !n = {%indep}.@count 'Construct a table to store the results table(4+!n,5) {%table} {%table}.setwidth(1:5) 10 {%table}.setlines(a2:e2) +d {%table}.setlines(a4:e4) +d {%table}.setformat(D) f.5 {%table}(3,1)= "Variable" {%table}(3,2)= "Coefficient" {%table}(3,3)= "t-Statistic" {%table}(3,4)= "Prob." {%table}(3,5)= "R-squared" for !v = 1 to !n {%table}(4+!v,1) = {%indep}.@seriesname(!v) next 'Find starting values equation {%eq1}.ls {%dep} {%indep} vector {%coef} = @subextract(c,1,1,!n,1) series {%resid} = resid !wparm = 2*({%eq1}.@se)^2 'weighting parameter !scale = @median(@abs({%resid} - @median({%resid})))/.6745 'scale parameter 'Initialize series and control variables series {%ser} =1 group {%indep}star vector(!n) {%coef}0 !tol=1 !count=0 'Start the loop while !tol >.00001 {%coef}0 = {%coef} {%resid} = {%resid}/!scale !count=!count+1 if model = 1 then {%table}(1,1)= "Huber's t function" {%ser} = !wparm/@abs({%resid}) {%ser} = @recode(@abs({%resid})<=!wparm,1,{%ser}) else if model = 2 then {%table}(1,1)= "Ramsay's E function" {%ser} = @exp(-!wparm*@abs({%resid})) {%ser} = @recode({%resid} =0,1,{%ser}) else if model = 3 then {%table}(1,1)= "Andrew's wave function" {%ser} = @sin({%resid}/!wparm)/({%resid}/!wparm) {%ser} = @recode({%resid}=0,1,@recode({%resid}>@acos(-1)*!wparm,0,{%ser})) else if model = 4 then {%table}(1,1)= "Tukey's biweight" {%ser} = (1-({%resid}/!wparm)^2)^2 {%ser} = @recode({%resid}=0,1,@recode(@abs({%resid})>!wparm,0,{%ser})) else {%table}(1,1)= "Tukey's biweight" {%ser} = (1-({%resid}/!wparm)^2)^2 {%ser} = @recode({%resid}=0,1,@recode(@abs({%resid})>!wparm,0,{%ser})) endif endif endif endif 'Weighted least squares series {%dep}star = {%dep}*@sqrt({%ser}) for !i=1 to !n series {%indep}star!i = {%indep}(!i)*@sqrt({%ser}) {%indep}star.add {%indep}star!i next series {%dep}hat=0 equation {%eq2}.ls {%dep}star {%indep}star {%coef} = @subextract(c,1,1,!n,1) for !j=1 to !n {%dep}hat = {%dep}hat+{%coef}(!j)*{%indep}(!j) next {%resid} = {%dep}-{%dep}hat 'Recalculate the tolerance level !tol = @max(@ediv(@abs({%coef}-{%coef}0),@abs({%coef}0))) wend 'Generate some basic equation output (can be extended further) stom({%indep}star,{%indep}m) !evar = @sumsq({%resid})/(@obs({%dep})-!n) vector {%coef}sig = @sqrt(!evar*@getmaindiagonal(@inverse(@transpose({%indep}m)*{%indep}m))) vector {%coef}t= @ediv({%coef},{%coef}sig) 'Store the generated output values into the table for !v=1 to !n {%table}(4+!v,2) = {%coef}(!v) {%table}(4+!v,3) = {%coef}t(!v) {%table}(4+!v,4) = @tdist({%coef}t(!v),@obs({%dep})-!n) next {%table}(5,5) = 1-(@sumsq({%resid})/@sumsq({%dep}-@mean({%dep}))) 'Final wrap-up if addc = 1 then {%indep}.drop {%const} delete {%const} endif delete {%coef}0 {%coef}t {%coef}sig {%eq2} {%indep}m {%indep}star* {%dep}hat {%dep}star show {%table} endsub
