syntax error
mattandlaura
syntax error
I have created a new eviews9 workfile and when I run a regression in the command line (nr c singd baht ringgit) and I receive a "syntax error." I have attached the eviews workfile. Can anyone help resolve this issue?
- natural_rubber.wf1
- (24.91 KiB) Downloaded 262 times
Re: syntax error
What is the exact command you used?
mattandlaura
Re: syntax error
The exact command is:
nr c sing baht ringgit
mattandlaura
Re: syntax error
Sorry about that, the command is:
mattandlaura
Re: syntax error
I found the issue, in the command prompt, i did not use the method, so it should have been
ls nr c singd ringgit baht
for the least square method, sorry about that.
