Transforming Alpha Series into Numeric
loulouviews
Postby loulouviews » Thu Mar 03, 2016 5:37 am
I'm currently facing the following problem:
I'm reading data from an html table. NAs in that table are encoded in two ways : either with blank or with "NaN".
When reading that table into EViews, EViews is interpreting the series containing NaN as alpha series.
I've tried to do :
wfopen(type="html") %url colhead=2 namepos=first na="NaN"
but it didn't worked.
I've tried to a loop amid the imported series to transform the alphas to numeric with :
group _g for !i=1 to _g.@count %name = _g.@seriesname(!i) {%name}=@val({%name}) next
But as all the series are not alphas, I got a "Numeric argument passed to string @VAL function" error when %name is a numeric series.
I've also tried
group _g for !i=1 to _g.@count %name = _g.@seriesname(!i) {%name}=@recode({%name}="NaN",na,{%name}) next
But it didn't worked either.
So how can I tell EViews that NAs can be either blanks or "NaN" ?
Or find a way to check if a series is alpha or not with a @isalpha kind of function ?
Thanks for your help.
Loulouviews
loulouviews
Re: Transforming Alpha Series into Numeric
Postby loulouviews » Thu Mar 03, 2016 7:55 am
I finally end up doing
group g_all * for !kk=1 to g_all.@count %name=g_all.@seriesname(!kk) if {%name}.@type="ALPHA" then rename {%name} _temp series {%name}=@val(_temp) delete _temp endif next delete g_all
If anyone has a more parsimonious and elegant solution, I'm eager to hear about it.
Postby EViews Gareth » Thu Mar 03, 2016 8:44 am
Use @wlookup
