hi,
I want to transform my variable into log but it gives me the following messageL
String argument passed to numeric log function
And then if I try to run a regression with the variable I get this message: syntax error.
if I include more than two variables, I get this message: alpha series in specification -net_income @ expand can convert to catagorical dummies
anyone can help?
indy
transform data into log
Re: transform data into log
The log function only works on numbers. You've passed in a string variable. EViews cannot take the log of strings.
coelhoindy
how to eliminate a string variable?
Assuming your string variable contains numbers stored as a string (possible, but unlikely), you can create a series with something like:
where myalpha is the name of your alpha/string series.
series myseries = @val(myalpha)
