String Loop on Existing String Variable
Posted: Thu Feb 18, 2016 7:59 am
Hello again,
I have a question on the following code:
Can I somehow use a string loop on an existing string variable that I declared so I don't have to type them all one by one? In another scenario, suppose that the string variable is updated then because my string loop doesn't know, it will only loop through the strings I manually typed there originally.
I tried:
But that didn't work.
Leave a line if you got an idea.
Thanks for reading
%labels = "height width length weight density"
%labels_xys = %labels
for %i height width length weight density
%labels_xys = @replace(%labels_xys, %i, %i+"_x "+%i+"_y ")
I tried:
for %i %labelsLeave a line if you got an idea.
Thanks for reading
