There is a bug in Eview's importing feature. I have an excel sheet where the eviews name of the variable are in line 1 and the eview's description of the variable are in line 2. When the variable does not exist in Eviews, and I import the data, Eviews will correctly import both the name and description. However, if the variable already exists, and I try to import the variable and overwrite the existing variable, Eviews will not import the description.
Attached are an Excel and Eviews file to replicate the bug. Try importing the data from the Excel file, and you'll see Eviews will fail to import the description.
Importing data description bug
- Example.xlsx
- (8.39 KiB) Downloaded 580 times
- example.wf1
- (9.43 KiB) Downloaded 501 times
Re: Importing data description bug
It isn't a bug, it is by design. Importing will never change/overwrite attributes.
