Converting a group into a system
Posted: Thu Nov 06, 2008 10:57 am
by CKIND
Is there a command that converts a group object into a system object?
The
makesystem
command only works with pool objects.
The menu in a system object allows you to import a group object with Proc/Define System... If you now choose a group object as Dependendent Variable, the group members are imported correctly into the system object.
Unfortunately, the
append
command for systems only seems to work with single equations (because they are a text input), not groups.
Is there a System Procs command that will do the job?
Re: Converting a group into a system
Posted: Fri Nov 07, 2008 11:16 am
Unfortunately there is not currently a command line method of doing this.
We'll investigate adding one at some point.
