Unwinding Dependent Variable Transformations
Posted: Tue Jan 26, 2016 10:37 am
When forecasting from an equation object with a dependent variable specified by expression, EViews gives users the option to forecast the base series or the expression.
For example in "ls d(rx_aud) c ar(1)", EViews will give the option to produce a forecast of RX_AUD or of the differenced series.
Is there are function or proc in EViews for mapping between these expressions and their most basic forms? E.g. I'd like to be able to take predicted values of an expression like "log(rx_aud)-@lag(log(rx_aud),4)" (coming out of a pool estimation) and map them back to predicted values of RX_AUD.
I can hard-code the unwinding of expressions for any specific case, but I'm hoping to write something more general.
Thank you for your help,
-James
-James
