Probability Density Question
Posted: Fri Jan 22, 2016 8:33 am
I understand how taking the integral of the probability density results in the cumulative distribution, and conversely, taking the derivative of the CDF results in the PDF, but what I'm not so clear on is if the typical calculus partial derivative interpretation is meaningful in this case.
The area under the PDF curve, for practical purposes, sums to 1, that's why taking the integral works, but what does this imply about the Y axis? The typical case, is Y= .398 for the max of the function. But what does this magnitude really mean? Is it the change in probability? Something akin to what we might observe in physics? Like the relation we see between acceleration and velocity, where acceleration is the change in velocity (as acceleration is the derivative of velocity)? Or are the y magnitudes that result when plotting the derivative PDF from the CDF meaningless?
To probe into this, I plotted the first difference of my CDF, and saw the same shape as the PDF, but the magnitudes were nowhere close. The highest change in probability was .07, a far cry from .398.
If someone can enlighten me, I'd do a backflip.
Thank you
Thank you
