Add vertical line in histogram
Zero
Postby Zero » Sat Jan 02, 2016 2:17 pm
Hello Eviews-Support Team,
I make am Monte-Carlo-Simulation with 10.000 observation and my workfile has about 78 mb.
Therefore I can only attach the program-code.
In the histogram, I can´t add a vertical line, with the dist option it works like it should.
Adding a horizontal line to a histogram works too.
My program-code is attached.
Thanks for your help.
P.S. I use Eviews 8.1 with the newest patch.
growth_mc_2_graph.prg
(3.87 KiB) Downloaded 510 times
Zero
Re: Add vertical line in histogram
Postby Zero » Mon Jan 04, 2016 4:36 am
Here is one page with a histogram and a distplot-graph. But to draw the vertical line only works in the distplot and not in the histgram.
graph_hist_dist_plot.WF1
(1.27 MiB) Downloaded 399 times
Postby EViews Jason » Mon Jan 04, 2016 9:43 am
In the histogram case, the position must be specified by observation number and not value.
The below line will add a vertical line at the 10th observation:
GRA_GDP1960_HAT_hist.draw(line, bot) 10
Zero
Postby Zero » Mon Jan 04, 2016 1:08 pm
First, I want to thank you for your request, Jason.
Is there no opportunity to set it by value, because I want to illustrate the case of a biased estimation
and the line should be the value from the data generating process.
Postby EViews Jason » Tue Jan 05, 2016 11:18 am
Unfortunately not.
Postby EViews Glenn » Wed Jan 06, 2016 1:26 pm
Actually, for the histogram, Jason's code will draw by value
graph01.draw(line, bottom) 824
will draw the vertical line at a value of 824.
Postby EViews Jason » Wed Jan 06, 2016 2:31 pm
Both Glenn and I are giving you conflicting answers. We are actually both right.
You cannot specify by value if from your series, you created the histogram by selecting view->descriptive stats & tests->histogram and stats.
You can if you create your histogram by selecting View->Graph, then selecting Distribution from the Specific: box and additionally selecting Histogram from the Distribution: box in the Details box.
