FRED error message
Posted: Fri Dec 18, 2015 7:56 am
by Tintin
When I try to export some FRED time series into my workfile from FRED database, I get a windows error stating the following:
"FRED library error, invalid conversion of NaN to double"
and the import into the workfile fails.
Some exports of the time series work finely, others don't.
Is there a fix for this problem ?
For example, a fetch that does not work is the symbol "ir3tib01huq156n".
Re: FRED error message
Posted: Fri Dec 18, 2015 9:52 am
by EViews Jason
What version of EViews are you using and are you up to date (select help->EViews update)?
If you are using EViews 9 which version of FRED are you using? If you select file->open->database, in the database/file type, are you using FRED database or FRED database V1?
Posted: Sat Dec 19, 2015 3:34 am
by Tintin
I am using Eviews 9 Enterprise edition, update 2015/12/14.
I used FRED database, but I just tried to run the export also in FRED database v1, which did not work either.
Posted: Wed Dec 30, 2015 5:45 pm
by EViews Jason
Can you try fetching the series again? We haven't been able to replicate the problem.
If you are still having problems, send a screenshot to support@eviews.com and reference this thread
