Exporting to excel - formatting issue
Posted: Fri Dec 18, 2015 7:23 am
by cc100
Hi Gareth,
I am running a program and then I am linking my eviews workfile results to excel using the eviews addin version 8.1 (excel version 2010). The data is always formatted as an excel table and if convert this to a standard range then I lose my links. How can I fix this?
Thanks!
Re: Exporting to excel - formatting issue
Posted: Fri Dec 18, 2015 9:45 am
Can you be more precise as to what you're doing and why it isn't working?
Posted: Mon Dec 21, 2015 2:41 am
by cc100
Hi Gareth,
I am basically copying and 'pasting as links' some matrices from my eviews workfile into an excel sheet. I am doing this so that I can just run my program every week and then refresh the excel sheet, which will pull in the new results. But when I paste in the results from eviews into excel, the matrices are formatted as tables, and if I change the formatting in excel then the link is lost. How can get the results to not be pasted in as tables?
Posted: Mon Dec 21, 2015 8:52 am
Pasting the link as Text will probably do it.
Posted: Mon Dec 21, 2015 9:15 am
by cc100
Hi Gareth,
Thanks for the quick reply. Excel only seems to let me paste as link or simply paste....If I just paste then obviously it is nolonger linked. Do you know whether there are some settings in excel I need to fiddle with?
Thanks!
Posted: Mon Dec 21, 2015 9:22 am
When you paste as a link, you have to specify the type you want to paste as:
Posted: Tue Dec 22, 2015 1:46 am
by cc100
Hi Gareth, Thanks for your screenshot. Attached is mine (using the eviews Getdata addin), the options are 'import and link' or 'import'.
Thanks.
Posted: Tue Dec 22, 2015 9:45 am
So when you said you were pasting, what you meant was that you were using the Excel Add-in (which is completely different...).
Try copy and pasting instead.
Posted: Wed Dec 23, 2015 1:15 am
by cc100
well originally i did state i was using the addin:
Hi Gareth,
Posted: Wed Dec 23, 2015 1:21 am
by cc100
And simply copy pasting does not work as it is nolonger a 'link' so it won't update when i update the program file
Posted: Wed Dec 23, 2015 7:53 am
Use paste special
