Question about Autocorrelation
Posted: Fri Dec 11, 2015 7:41 am
by Ynwe
Hey,
In my output I have an obvious issue with autocorrelation. Durbin-Waston has a value of 1.1 and a Q-Statistic under Residual Diagnostics shows me pretty much that I have autocorrellation. So I add an AR (1) term. Now durbin watson goes up to 1.6, the Q-Statistic overall seems to be fine too now, but one of my key variables has a p value increase from .0347 to .21. The AR term itself is significant at a 5% level (0.0404). What does this mean? Does this mean I have to throw that variable out now, given that I add a AR 1 term?
Re: Question about Autocorrelation
Posted: Fri Dec 11, 2015 8:09 am
by startz
The fact that a variable is "insignificant" does not mean you should throw it out.
Posted: Fri Dec 11, 2015 3:02 pm
by Ynwe
but why does the adding of an AR term suddenly render a variable insignificant?
Posted: Fri Dec 11, 2015 3:05 pm
by startz
Generally because when serial correlation is ignored the reported standard errors are wrong. Adding AR(1) gives the correct standard errors. In addition, sometimes serial correlation indicates misspecification.
Posted: Sat Dec 12, 2015 2:55 am
by Ynwe
so this means, that in the original output, the standard errors were wrong due to a AR taking place that the model was ignoring. This led to GDP being given as a significant variable due to miscalculations. Adding an AR term yields it insignificant at a high level. so due to the addition of the AR term, we know that the past values are explaining present and future values to a certain extent and that the GDP variable does actually not add significant information to the regression that I originally thought it was doing. Is there anything else to say about AR and the Variable GDP?
Also, the SC, AIC and Hannan-Quinn Criteria haven't improved by much between these two modells. Wouldn't this mean that the addition of the A term overall only made the new model only very slightly better than the older one`?
Posted: Sat Dec 12, 2015 7:51 am
by startz
That seems right.
