Simple T-test
Posted: Wed Dec 09, 2015 6:34 pm
by gka
Hello guys, I want to estimate the Cov(b1,b2) from the models below:
y=a1+b1X1
y=a2+b2X2
Do you know how to do this?
Ps. I want to check if H1:b1=b2 or H2:b1#b2, for t-test=(b1-b2)/sqrt(Var(b1)+Var(b2)-2Cov(b1,b2))
Is there an other way to do this?
Re: Simple T-test
Posted: Wed Dec 09, 2015 8:58 pm
Put the equations in a System.
Re: Simple T-test
Posted: Thu Dec 10, 2015 12:03 pm
by gka
The problem is that I have beta coefficients from guantile regression... and this is not easy to do something like this.
Thanks...
Is there any other idea?
Re: Simple T-test
Posted: Thu Dec 10, 2015 2:01 pm
by trubador
Startz' suggestion is the way to do what you want. However, based on your last post, I understand that the equations are already estimated (somewhere else) and you happen to have b1 and b2 parameters from a number of equations. If that is the case, then the following resources might be of help:
http://www.eviews.com/help/helpintro.ht ... 10.html%23
http://www.eviews.com/help/helpintro.ht ... 23ww132090
Re: Simple T-test
Posted: Sun Dec 13, 2015 9:02 pm
by gka
Yes the equations already estimated. But the problem is that I have about 100 b (b1 b2 b3 ... b100) from monte carlo simulation I want to check all of this with the first b1. On the other hand, the basic problem is that I have some equations from quantile regression...
Re: Simple T-test
Posted: Sun Dec 13, 2015 9:58 pm
Can you compute the covariance from the monte carlo simulated coefficients?
