Separate regression based on categorical variable
Posted: Wed Dec 09, 2015 4:53 am
I would like to ask if there is any command to run separate regressions based on a categorical variable.
For example, I have a categorical variable GENDER with 1 = male and 0 = female.
I would like to generate a regression only with male data and a separate one only with female data.
Is there a command to do this directly using the same dataset or do I have to manually separate them into two files and run them separately?
Thank you for your clarification.
