Access Table Data in Formula?
Posted: Fri Dec 04, 2015 9:02 am
by kcaron
Is it possible to write a formula that references a cell in a saved EViews table?
If so, what is the method for doing so?
Thanks!
-K
Re: Access Table Data in Formula?
Posted: Fri Dec 04, 2015 9:21 am
Define what you mean by formula.
Posted: Fri Dec 04, 2015 9:58 am
by kcaron
Formula for a line... Where my independent variables are stored in a table and the coefficients are drawn from a regression equation.
dependent = regression.c(1) * independent + regression.c(2)
Where...
regression.C(1) is the coefficient and regression.C(2) is the constant from a saved regression equation (called "regression"), and
independent is some number that I make up and store in a table. (Let's say the table is called "mytable")
Thx!
K
Posted: Fri Dec 04, 2015 10:01 am
Sorry, what do you mean by "line"?
Are you trying to create a formula object?
Posted: Fri Dec 04, 2015 10:04 am
by kcaron
yes. sorry.
Posted: Fri Dec 04, 2015 10:06 am
You can refer to the table cell just from mytable(3,1). But the formula will not dynamically update every time the table updates. Formula objects only update when series do.
Posted: Fri Dec 04, 2015 10:37 am
by kcaron
Hmmmm...
I'll play around with it. Thank you!
-K
