Calling % sign instead of using it as a string variable
Posted: Fri Nov 27, 2015 1:02 pm
by CharlieEVIEWS
I want to replace % in alpha series. However, when i replace it with the line:
alphaseries = @replace(alphaseries, "%","percent")
when I run the program, I think EViews interprets it as a string variable and the series window shows the replacement line as:
Modified: 1 252701 =>
alphaseries = @replace(alphaseries, "","percent")
How do I call this special reserved character into string functions instead as a character instead of a string variable?
Apologies if I'm missing an obvious issue.
Re: Calling % sign instead of using it as a string variable
Posted: Fri Nov 27, 2015 1:18 pm
create u 100
alpha a = "100%"
a = @replace(a, "%", "percent")
show a
Posted: Fri Nov 27, 2015 1:22 pm
by CharlieEVIEWS
Doesnt work for me. Must have changed an option.
Last updated: 11/27/15 - 20:21
Modified: 1 100 // a = "100"
Modified: 1 100 // a = @replace(a, "", "percent")
percentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentpercentperc
Posted: Fri Nov 27, 2015 1:38 pm
Are you running programs in v4 compatibility mode?
Posted: Fri Nov 27, 2015 1:46 pm
by CharlieEVIEWS
Yes. I am. For a reason which I dont remember, I need to. Any way to circumvent the above problem while being in this mode?
Posted: Fri Nov 27, 2015 1:51 pm
No. Version 4 did not have alpha series.
Posted: Fri Nov 27, 2015 2:18 pm
by CharlieEVIEWS
Im also guessing I cant change this option 'on the fly' ?
Posted: Fri Nov 27, 2015 3:00 pm
I'm only on my phone at the moment, so can't check for certain, but I believe you can only turn on ver4 compatibility and not turn it off.
http://www.eviews.com/help/helpintro.ht ... 23ww103410
