R, xopen(type=r)
Posted: Fri Nov 13, 2015 8:11 am
I have a problem when installing R to use the xopen(type=r) command.
I try to follow the procedure in the Eviews help manual, but when verifying the installation "Once installation is complete, run the statconn “Server 01 - Basic Test” program, usually found under Start->All Programs->statconn->DCOM->Server01 – Basic Test, to verify that everything is working. Click on the Start R button to begin the test.", i get the message:
Loading StatConnector Server... Done
Initializing R...Function call failed
Code: -2147221455
Text: licensing: license expired
Releasing StatConnector Server...Done
see also atached word document. What should I do to proceed?
Code: -2147221455
