@insert function for strings
cap
Postby cap » Wed Sep 02, 2009 4:01 pm
I am trying to use the @insert function, and it seems to generate errors in even the simplest attempt at using it.
For example, if I have the line:
%mystr = @insert("helo","l",3)
then I get the error message %MYSTR is not defined or is an illegal command
How should I be using this function then?
Thanks in advance,
-cap
Re: @insert function for strings
Postby startz » Wed Sep 02, 2009 5:08 pm
I'm not sure if this is what you want, but
alpha mystr = @insert("helo","l",3)
works
Postby EViews Gareth » Wed Sep 02, 2009 5:21 pm
Looks a bit like a bug to me, I'll investigate.
cap
Postby cap » Thu Sep 03, 2009 9:13 am
Thanks startz, that followed up with @elem() does allow me to get the particular string I want.
It would still be nice to see if the original @insert function could be made to work though (thanks Gareth).
-cap
