FRED/ALFRED series attributes question
Posted: Fri Oct 02, 2015 11:42 am
Dear all,
I really like the new fred/alfred integration, and I made extensive use of the EV8 version. It makes life a lot easier than using the fredapi wrapper in python directly. This becomes even more true when you want to obtain a series at a given date (e.g. the @ suffix) in
which i imagine is just a substitute for fred.get_series_as_of_date('gdpdef', '1/1/2015') if its going through some kind of python backend.
However, I have just one query and was wondering if you could provide some guidance. When youre in the FRED database window and you double click a queried series, you can bring up all the attributes of the series which comes from the DataFrame of that query (e.g. name = series id, description=title(?) etc, frequency, popularity). Is there any way (or workaround?) to pull this information into a workfile dynamically, using fetch or copy? I'm not too hot on databases in EViews, but any advice on this would be really useful. One thought might be to freeze the series attributes or something? But it isnt an object, so I cant quite figure it out.
Thanks again for all your efforts with this integration, and of course - best wishes as always.
Charlie
Edit: If this isnt currently possible in any way and should go into the 'suggestions' subforum, then please feel free to move the thread!
copy fred::gdpdef@20150101 untitled::gpdef20150101However, I have just one query and was wondering if you could provide some guidance. When youre in the FRED database window and you double click a queried series, you can bring up all the attributes of the series which comes from the DataFrame of that query (e.g. name = series id, description=title(?) etc, frequency, popularity). Is there any way (or workaround?) to pull this information into a workfile dynamically, using fetch or copy? I'm not too hot on databases in EViews, but any advice on this would be really useful. One thought might be to freeze the series attributes or something? But it isnt an object, so I cant quite figure it out.
Charlie
