unlinking/cleaning data eliminates entries
Posted: Thu Oct 01, 2015 2:35 am
i have noticed that unlinking data or using @clear for frmls selectively eliminates all the entries; this was not the case previously (the macro i use for this proceedure is years old); what is so confusing is that there seems not to be a pattern when something will be erased or not;
to replicate the problem goto the export worksheet open e.g. all y_m_cbrate_us_* as group and look at all the data, run the command unlink * ; after that the entry y_m_cbrate_us_fcw will disappear; note, this is also the case when using @clear for each single entry if used in a macro; if you do it selectively - i.e. goto the individual series and unlink it manually by putting it back to values, it will keep the values in the series;
best
Michael
best
Michael
