file paths with spaces
Posted: Tue Sep 22, 2015 10:12 am
by Jonathan
This question is similar to that of the Defining Path thread although the responses there don't seem to be helping.
I'm trying to do something like this:
%curr_path = "Z:\Forecast_Sales\Results\0815\ABC August 2015 Sales Results.xlsx"
%half2 = " byrow colhead=2 namepos=last na=""#N/A"" @freq Q @id @date(variable) @destid @date @smpl @all"
for %tab " range=2015 Middle" " range=2015 Upside" " range=2015 Downside"
%command = """" + "import " + %curr_path + %tab + %half2 + """"
{%command}
But it doesn't work. I'm clearly not understanding the treatment of spaces and use of quotes. Any explanation or code suggestion or reference location would be appreciated. Thanks,
Jonathan
Re: file paths with spaces
Posted: Tue Sep 22, 2015 11:04 am
You need to put quotes around the %curr_path.
Something like:
%command = "import " + """" + %curr_path + """" +%tab + %half2 {%command}
Posted: Tue Sep 22, 2015 11:45 am
by Jonathan
Thanks, that did it. I also hard-coded the range= and put double quotes around the tab name.
%command = "import " + """" + %curr_path + """" + " range=" + """" + %tab + """" + %half2
Thanks again,
Jonathan
