Page 1 of 2
Making Eviews open excel
Posted: Mon Sep 21, 2015 2:11 pm
by ian.e.preston
I have a program that imports data from an excel file. For some reason it will only successfully import the data if I have the excel file open prior to running the program. This is not an issue with other excel files. What I'd like to do as a hack-y solution is just call excel to open the file from my eviews program. Failing that I guess I'd like to find out why I can't pull from this particular file and fix it that way. Any tips?
Re: Making Eviews open excel
Posted: Mon Sep 21, 2015 2:30 pm
Best thing to do would be to provide us with the Excel file so we can try and figure out why EViews cannot open it.
Posted: Mon Sep 21, 2015 2:33 pm
by ian.e.preston
That does seem best. Here you go.
Import code is as follows:
%secfrom = [path]\LTC_Sec_monthly.xlsx" import %secfrom range=Page1_1 @id Claim @destid @date
Posted: Mon Sep 21, 2015 5:01 pm
by EViews Jason
EViews couldn't auto detect the date series 'claim' since it is out of order. It is in alphabetic order but not time order.
I also do not notice a difference as to whether or not Excel is open or not. In both cases, the above problem exist.
With that being said, try using
import ltc_sec_monthly.xlsx range=Page1_1!$A$1:$L$189 colhead=1 na="#N/A" @freq M @id @date(claim) @smpl @all
Posted: Tue Sep 22, 2015 7:59 am
by ian.e.preston
Same issue. If I run it with the excel file closed I get this error:
Unable to determine date format of object CLAIM in [PATH] range=Page1_1!$A$1:$L$300 colhead=1 na="#N/A" @freq M @id @date(claim) @smpl @all
If I open the excel file first and then run the program it's fine.
Excel 2010 and Eviews 9 - July 23 2015 build.
Posted: Tue Sep 22, 2015 8:15 am
Could you try updating to the latest version of 9?
Posted: Tue Sep 22, 2015 8:17 am
by ian.e.preston
I can't actually. IT at work has pretty strict version control. I'd have to make a whole business case etc.
Posted: Tue Sep 22, 2015 9:04 am
Try opening the file in Excel, saving it locally, then closing down Excel and trying to open it in EViews. Does that work?
Posted: Tue Sep 22, 2015 9:32 am
by ian.e.preston
Saved the file to my desktop, it was on a network mapped drive before. Exact same issue.
Posted: Tue Sep 22, 2015 9:50 am
What happens if you try to open it interactively?
Do any of the data get read in correctly?
Our best guess is that it is an Excel security issue.
Posted: Tue Sep 22, 2015 9:54 am
by ian.e.preston
Not sure what you mean by interactively. Can you clarify?
I'm stumped too, this file is generated by Cognos report studio, saved on a network drive. Other reports generated in the same manner saved in the same location don't have this issue. The one distinction I can think of is that the date is sorted alphabetically, as was pointed out. I don't know why having the file open in excel makes a difference for that though.
Posted: Tue Sep 22, 2015 10:41 am
by ian.e.preston
Ok, I recoded the query so dates are in chronological order. Same error.
Posted: Tue Sep 22, 2015 11:05 am
If you use File-Open rather than using a command to open the file.
Posted: Tue Sep 22, 2015 11:11 am
by ian.e.preston
I think I'm missing something here. Are we talking about the excel file or the eviews file?
Here are the combinations I can think of, and the outcomes that result from them:
Attempt to import into eviews without Excel open:
-Importing the data via script claims.prg - previously quoted error message
-From eviews opening my workfile, going to file -> import and trying to load the data - only shows claim header, no other columns for sectors and no actual data, can't import
Have Excel file open prior to importing to Eviews:
I can do this by double clicking the Excel file, or opening excel and the going to file -> open and loading the file, no difference
Both manual import and importing via script work fine
Does this help narrow it down?
Posted: Tue Sep 22, 2015 12:09 pm
Somewhat.
What happens if you save it as .xls rather than .xlsx?
