Modify graph axis
Posted: Fri Sep 11, 2015 4:08 am
by hakperest
Hello ,
I have a graph that was plotted
command. I want modify bottom axis that should be as like as following image. Bottom axis may contain only ordered number (without zero or decimal pointers). How can I do that?
Huseyin
Re: Modify graph axis
Posted: Fri Sep 11, 2015 8:56 am
by EViews Jason
We are going to need more context. If you have an undated workfile this should already happen, unless I am completely missing what you are asking.
Posting your workfile or an example workfile would be helpful.
Posted: Sat Sep 12, 2015 12:44 pm
by hakperest
My code is:
graph gr_multi.line(a) new
gr_multi.shade(shade, left) 0
gr_multi.options linepat
gr_multi.setelem(2) lcolor(black) lwidth(2) lpat(1)
and my file is attached.
I need my graph be scaled automatically.
Ploted series have restricted sample and contains only 40 length then bottom axis should be start with zero and continiues until 40.
Posted: Mon Sep 14, 2015 9:38 am
by EViews Jason
You will have to create a series with the desired labels and then create a XY line graph.
load eviewstest
series trend=@trend
series index = trend-@first(trend) 'create an index series starting at the beginning of the sample
group mygroup index new
freeze(gr_multi2) mygroup.xyline
Posted: Fri Sep 18, 2015 10:20 am
by hakperest
Your code was great but there is some other problems with this method.
I used following codes and graph shows more timeset. I want it show only bottom axis between zero and 80 but this method shows it within -10 and 90. Where my data includes only zero to 80.
%trend=@getnextname("ZZ__trend")
%index=@getnextname("ZZ__index")
%mygroup=@getnextname("ZZ__mygroup")
series {%trend}=@trend
series {%index} = {%trend}-@first({%trend})-1
%legendArti=%i+ " +"
%legendEksi=%i+ " -"
' graph {%graph}.line {%i}_2_0m -{%i}_2_0m ({%i}_2_0m -{%i}_2_0m)
group {%mygroup} {%index} {%i}_2_0m -{%i}_2_0m ({%i}_2_0m -{%i}_2_0m)
freeze({%graph}) {%mygroup}.xyline
{%graph}.shade(shade, left) 0
{%graph}.options linepat
{%graph}.setelem(1) lcolor(black) lwidth(3) lpat(2) legend()
{%graph}.setelem(2) lcolor(black) lwidth(2) lpat(1)legend({%legendArti})
{%graph}.setelem(3) lcolor(red) lwidth(2) lpat(1) legend({%legendEksi})
{%graph}.setelem(4) lcolor(red) lwidth(1) lpat(2) legend(diff)
{%graph}.setelem(5) lcolor(red) lwidth(1) lpat(2)legend()
{%graph}.setelem(6) lcolor(red) lwidth(0) lpat(2) legend()
{%graph}.options size(4,2) -inbox
{%graph}.legend position(botcenter)
Posted: Fri Sep 18, 2015 4:05 pm
by EViews Jason
Your sample code does not run for me. I am missing some series such that the following line gives an error
In any case, in your code you also have
Did you mean to add the '-1'. If you remove it I believe it will fix the problem
Posted: Sat Sep 19, 2015 2:16 am
by hakperest
Thanks a lot. My problem solved with changing smpl :)
Bu I found an bug about plotting with xyline command.
xyline command ignores first series when it plot and colourized but start from first (trend in this example) when legend command is used.
%graph="linegraph"
d {%graph}
graph {%graph}.line x1 x2 x3
{%graph}.setelem(1) lcolor(black) lwidth(2) lpat(2) legend(x1)
{%graph}.setelem(2) lcolor(black) lwidth(2) lpat(1)legend(x2)
{%graph}.setelem(3) lcolor(red) lwidth(2) lpat(1) legend(x3)
group mygroup trend x1 x2 x3
%graph="xylinegraph"
freeze({%graph}) mygroup.xyline
Posted: Tue Sep 22, 2015 8:07 am
by EViews Jason
Trend isnt being ignored, it is the x axis. So it will not appear as another line. You are graphing trend vs x1, trend vs x2 and trend vs x3. So this appears correct.
Because Trend is the first element in the group, when setting the legend labels for the other series you have to skip Trend. This I admit may not be intuitive but I think you want
{%graph}.setelem(2) lcolor(black) lwidth(2) lpat(2) legend(x1)
{%graph}.setelem(3) lcolor(black) lwidth(2) lpat(1)legend(x2)
{%graph}.setelem(4) lcolor(red) lwidth(2) lpat(1) legend(x3)
