How to change both name and display name of variable
loulouviews
Postby loulouviews » Mon Sep 07, 2015 7:10 am
I've a bunch of variable I'm importing from a HTML page with the function wfopen. The webpage also provides names (that I want to change) and description (that I want to keep).
Then I rename those variables with the rename X Y EViews function. Unfortunately, EViews does not change the displayname of the variables.
Does anybody have an idea to change both name and displayname of a variable ?
Thanks in advance,
Loulouviews
PS : I'm using EViews 8
Re: How to change both name and display name of variable
Postby EViews Gareth » Mon Sep 07, 2015 10:59 am
You'll have to use the series.displayname command to change the displaynames separately.
loulouviews
Postby loulouviews » Mon Feb 29, 2016 1:46 am
I'm reopening this thread because I'm renaming series by doing
rename {%oldname} {%newname}
But when plotting the series, EViews still displays the oldname.
Since I've more than 8000 series renamed in a loop and renaming each sequentially, I'd prefer not doing another loop with .displayname proc.
Thanks a lot in advance !
Louis
Postby EViews Gareth » Mon Feb 29, 2016 9:17 am
I think you have no choice.
loulouviews
Postby loulouviews » Wed Mar 02, 2016 3:58 am
Ok, thanks for your reply.
How can I get the original name of a variable then ?
Here is my problem : I'm reading series from a .tsv file. EViews is reading it perfectly except for a bunch of variables which got a name longer than 24 characters.
EViews automatically renames them but it also stores the "real name" in a "original name" field.
How can I get access to it ?
I would imagine something like :
string %myName=name_of_the_series.@originalname
Thanks for your help.
Postby EViews Gareth » Wed Mar 02, 2016 9:19 am
Try:
%myname = name_of_series.@attr("originalname")
loulouviews
Postby loulouviews » Wed Mar 02, 2016 10:29 am
Thanks a lot for your reply !
Finally I noticed that the displayname was still the original name so I did
%name=name_of_series.@displayname
cmm1603
Postby cmm1603 » Mon May 02, 2016 1:37 pm
Hi there,
I imported data from a Eurostat table and I want to know how I can change multiple variables names collectively by assigning a prefix to all of them. I know how to rename variables one by one but want to know if there's a more time efficient way to do this.
All variables start with different things (list of variable below as an example):
currency_and_deposits
equity_investments
long_term___loans
unlisted_shares
I want to be able to add a prefix such as "gga" in front of all the names:
gga_currency_and_deposits
gga_equity_investments
gga_long_term___loans
gga_unlisted_shares
Is this doable?
Postby EViews Gareth » Mon May 02, 2016 1:49 pm
rename * gga_*
You might/will hit the 24 character maximum though.
bobhughesaier
Postby bobhughesaier » Thu Jun 02, 2016 11:30 am
Any plans to expand that 24 character limit?
Postby EViews Gareth » Thu Jun 02, 2016 11:47 am
It is on the list of things to contemplate, yes.
bobhughesaier
Postby bobhughesaier » Thu Jun 02, 2016 12:24 pm
OK. So, it doesn't sound like it'll be in the next version/update. For what it's worth, it gets my vote as a high priority. Thanks Gareth.
