SWITCHREG
Posted: Tue Sep 01, 2015 2:47 am
by maxchen
EV 9 x86, 20150825
first, the data
rs.WF1
data workfile
(15.3 KiB) Downloaded 412 times
setmaxerrs 1000 wfuse rs.wf1 equation eqb.switchreg(type=markov,heterr,s,coef=b) ds c df freeze(tb00) eqb.output
the error msg
Near singular matrix in computing the steady state probabilities in "EQUATION EQB.SWITCHREG(TYPE=MARKOV,HETERR,S,COEF=B) DS C DF".
EQB is not defined in "FREEZE(TB00) EQB.OUTPUT".
the estimation fail, however, the equation object EQB is not created. I think that EQB is first created, and then do the SWITCHREG
If I change the codes slightly
setmaxerrs 1000 wfuse rs.wf1 equation eqb eqb.switchreg(type=markov,heterr,s,coef=b) ds c df freeze(tb00) eqb.output
this time, I define the equation object first. the error msg:
Near singular matrix in computing the steady state probabilities in "DO_ EQB.SWITCHREG(TYPE=MARKOV,HETERR,S,COEF=B) DS C DF".
Equation estimates are not valid in "FREEZE(TB00) EQB.OUTPUT".
the freeze output is the eqb.spec
other suggestion: as http://forums.eviews.com/viewtopic.php?f=8&t=12373
I hope that add one data member, such as eqb.@conv:
-1 if there is an error
0 if no convergence
1 if done
2 if "Failure to improve objective (non-zero gradients) after xxx iteration"
and add one data member for warnings, such as eqb.@warn:
0 no warning
1 "WARNING: Singular covariance - coefficients are not unique"
then the problem in http://forums.eviews.com/viewtopic.php?f=4&t=12577 will handle more efficiently in prg mode.
Re: SWITCHREG
Posted: Tue Sep 01, 2015 3:01 am
by maxchen
The regime switching model is extremely volatile
setmaxerrs 1000 wfuse rs.wf1 equation eqb eqb.switchreg(type=markov,heterr,s,coef=b) ds c df 'equation eqb.switchreg(type=markov,heterr,s,coef=b) ds c df freeze(tb00) eqb.output eqRS.switchreg(type=markov,heterr,rng=mt, seed=413176807,showopts) ds c df freeze(tb01) eqRS.output ' standard deviation (rng=mt, seed=1728250922) eqRS.switchreg(type=markov,heterr,rng=mt, seed=1728250922,showopts) ds c df freeze(tb02) eqRS.output ' standard deviation (rng=mt, seed=1440242362) eqRS.switchreg(type=markov,heterr,rng=mt, seed=1440242362,showopts) ds c df freeze(tb03) eqRS.output ' standard deviation (rng=mt, seed=1161274805) eqRS.switchreg(type=markov,heterr,rng=mt, seed=1161274805,showopts) ds c df freeze(tb04) eqRS.output ' standard deviation (rng=mt, seed=1814116667) eqRS.switchreg(type=markov,heterr,rng=mt, seed=1814116667,showopts) ds c df freeze(tb05) eqRS.output
we may arrive at NA Std Error. see tb01 tb02
Even we are lucky to achieve convergence, the coefs may widely different, see tb03 tb04 and tb05
To estimate difficult models, EViews should provide additional data member, to aid in prg mode.
