Selecting data within the series - EV8
H_Boss
Postby H_Boss » Sat Aug 29, 2015 3:19 pm
I have series with multiple countries. Is it possible to filter 1 or several countries on estimation?
Thanx,
HB
Re: Selecting data within the series - EV8
Postby EViews Gareth » Sat Aug 29, 2015 3:34 pm
Probably, but without more details it is impossible to give advice.
H_Boss
Postby H_Boss » Sat Aug 29, 2015 7:50 pm
I wish to do the estimation with only 1 or some o'the countries in the series.
Is there a command like in SQL, "where country=Austria", f.e.?
HB
Postby EViews Gareth » Sat Aug 29, 2015 7:58 pm
Set the sample to be
If county = "Austria"
H_Boss
Postby H_Boss » Sun Aug 30, 2015 6:20 am
? on the estimation equation?
Postby EViews Gareth » Sun Aug 30, 2015 7:40 am
Yes
H_Boss
Postby H_Boss » Sun Aug 30, 2015 7:45 am
Error... "Near singular matrix."
Is this correct?
1980 2012 if country = "Austria"
Postby EViews Gareth » Sun Aug 30, 2015 8:04 am
That's correct.
H_Boss
Postby H_Boss » Sun Aug 30, 2015 8:26 am
Why the error then?
Postby startz » Sun Aug 30, 2015 8:39 am
Do you have a variable with constant value for Austria?
H_Boss
Postby H_Boss » Sun Aug 30, 2015 8:41 am
No, the values for Austria vary over the years 1980-2012. As for other countries.
Postby startz » Sun Aug 30, 2015 8:49 am
You might want to form the correlation matrix of all your right hand side variables, keeping the sample to Austria. Or you might want to post your workfile to see if anyone else sees anything.
H_Boss
Postby H_Boss » Sun Aug 30, 2015 8:52 am
Here it is...
regressao.wf1
Here it is...
(212.54 KiB) Downloaded 242 times
Postby startz » Sun Aug 30, 2015 9:21 am
Please remember that while you're deeply involved, no one else understands the context. You need to tell us what equation you estimated, what options you used, etc.
H_Boss
Postby H_Boss » Sun Aug 30, 2015 9:31 am
Equation: logco2 c logres loghydro logfossil lognuclear loggdp logindustry urbpop
Method: Least squares, 1980 2012
Fixed effects, GLS: No weights.
Coef covariance method: I'm still trying to find that out (diff. post), using "Period weights" for now.
