Eviews 9 crashes when loading data in SAS file
Posted: Thu Aug 13, 2015 1:16 am
Im loading several SAS (sas7bdat) data files. Most of the files are less than 5 GB. However, when loading a data file that is 8.5 GB Eviews just stops working. I have kept an eye on the amount of memory used by Eviews, but it is much less than what is available on the network (20 GB). I am therefore not sure what is causing this error.
Unfortunately, I cannot send you this data due to confidentiality.
When loading the file, I can first choose which variables to read. Then Eviews starts to read the series. After abut 68% is remaining, it stops working (see image).
Do you have an idea what can be causing Eviews to crash? Is there anything I can do to find out what the error is?
