I get a problem with stom command. I defined a matrix to be 5x65 and have group of exactly 65 series with 5 observations each. Yet, each time I run the code, I get the msg "Insufficient number of observations". Any idea what can be wrong?
Stom command
Re: Stom command
We'd need to see the program, and probably the workfile.
Re: Stom command
You could try without first creating the matrix as stom should create it for you. But if I had to guess I'd say the workfile sample is set such that there are no valid observations in one or more of the series in the group.
Re: Stom command
In which case you could try stomna
