I was wondering of whether there is a command to retrieve the adjusted sample used for estimation of an equation. The current @smpl command provides the sample size set by me which does not necessarily coincide with the sample used for estimation. I want to run a loop over a bunch of equations, and I want to avoid getting it by freezing the equation output window.
Many thanks in advance.
PS Eviews 9, Enterprise Edition, July 1 2015 build (64-bit version)
Retrieve adjusted sample
Re: Retrieve adjusted sample
No, because it is probably not a simple sample statement. You're better off using makeresids to make the residual series and then setting the sample to if resid<>0
