HI there
I estimated a GARCH model and now I want to calculate the variance covariance matrix of the coefficients (I can obtain this by View -> Covariance matrix). HoBut how is this calculated in Eviews?
As there is a constant in the mean and variance equation, X'X is not invertible, where X is a matrix of all the regressors in the model. So how can we possible do this?
Best
S
Covariance matrix of coefficients with GARCH models
Re: Covariance matrix of coefficients with GARCH models
A thoughtful question, but why do you think X'X is not invertible? The variables in the mean and variance equations don't enter linearly.
Hi Startz
Thanks for your answer. So how can I calculate it then? I looked online and textbooks, but was unsuccessful in finding an answer. Any references?
Best
s
Best
s
I believe the GARCH variance is just the usual maximum likelihood variance estimator, but maybe one of the EViews folks or Trubador could chime in.
Startz is right. You can try the following and see it for yourself:
'Create a workfile
wfcreate u 1000
'Generate an exogenous series
series x = nrnd
'Generate a y series that follows a GARCH-X(1,1) dynamic (use TSDGP add-in)
tsdgp(meanconst="5",meanexog="2*x",varconst="1", arch = "0.08", garch="0.91") y
'Estimate the model
equation eq.arch(backcast=1) y c x
'Save the gradients and store as a matrix
eq.makegrads(n=grads)
stom(grads,gradmat)
'Compute the covariance matrix (OPG)
sym varcov=@inverse(@transpose(gradmat)*gradmat)
'Save the covariance matrix from the estimated equation for comparison
sym eqcov = eq.@coefcovRe: Covariance matrix of coefficients with GARCH models
Brilliant! Thanks you so much for this. Very much appreciated!
Best
s
Best
s
