SE of regression with GARCH models
Posted: Sat Jul 04, 2015 7:03 am
Hi there
I estimated a GARCH model and wanted to replicate the S.E. of regression. The formula given in the help for this statistic is given by
square root of (Residual sum of squares)/(Nr of observations - number of regressors).
I noticed, however, that Eviews uses only the coefficients in the mean equation as number of regressors. So for example, if I estimate a AR(2)-ARCH(1) model with a constant in the mean and variance equation. The number of regressors used in the formula above is 3 and not 5. Is this ok?
Thank you!
Best
s
Thank you!
Best
s
